Go Back   My Verizon Users > The Basics > Ask the Tech?
Ask the Tech? Here you can ask specific questions to Technical Staff working at Verizon Wireless. They can answer specific questions that are not confidential. Ask away!
Old 06-20-2007, 04:02 PM   #1 (permalink)
islander5151 is on a distinguished road
Default SD card not working
I have a samsung 990 and I tried to put songs on there to listen to put when I put the card in, it says no songs. I tried to format it to see if that would work but it just says Formating Failed. Is there anything I can do?
islander5151 is offline   Reply With Quote
Old 06-20-2007, 06:32 PM   #2 (permalink)
Look under our Samsung a990 section.
In general, the song has to be in certain location before the phone can recognize that there are songs.
What you do is, insert the blank SD card into the phone and the phone will create bunch of directories on the SD card. Then, you take the SD card out, put it in your pc or a laptop, put the songs in the proper location. Next time you put the SD card back, the phone should recognize them as songs.
Again, check the section above for more details.
How to insert / remove a memory card on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:54 PM
How to insert / remove a memory card on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 02:54 AM
PC Card FAQ admin_mvu Wireless PC Cards 0 01-02-2008 09:55 PM
