Basic Features Discuss basic features that are available on all phones here
Old 11-13-2007, 10:44 AM   #1 (permalink)
Default Call Waiting
Description
<!-- mba_share_description_start --> This feature lets you know when another caller is trying to reach you while you’re on another call. You will hear a short tone. After you hear the Call Waiting tone, you’ll have approximately 30 seconds to answer before the second caller hears a standard message or is forwarded to your Voice Mailbox. If you answer the call, airtime and other usual charges will apply to both calls until you end one call.<!-- mba_share_description_end -->
How to Get It
Call Waiting is an included feature that is typically added to your account when you first activate service. if you wish to confirm you have this feature, login to My Account and select "My Plan", then select "Add/change features".
<!-- mba_share_how_to_use_start -->
How to Use It
To Initiate Call Waiting:
When you're on the line and a second call comes in, you'll hear a tone to let you know you have another call. When that happens, you have three choices:
  1. Put the first call on hold by pressing SEND. You'll automatically be connect with the second call. To return to the first call: Press SEND again. To switch between the two calls: Press SEND.
  2. Or, end the first call by asking the first caller to hang up. This automatically connects you to your waiting call.
  3. Or, ignore the Call Waiting tone. After 30 seconds, the waiting caller will hear a message indicating that you're not available, or will be forwarded to your voice mailbox if you subscribe to a messaging service.
To Cancel Call Waiting:
Before a call, dial *70 + the 10-digit number you are calling + SEND.
External screen duration during call question. JammasterKX2 LG Voyager 0 10-21-2008 07:43 PM
Missed Call Alert WANTED firstdate1 Palm Centro 1 10-11-2008 02:46 PM
LG VX8350 One Missed Call Problem... Sithtiger LG VX8350 0 05-22-2008 10:18 PM
Call Forwarding admin_mvu Basic Features 0 11-13-2007 10:40 AM
Info you need every day is just a phone call away. buzzdar Tips & Tricks 1 07-27-2007 09:43 AM
