Go Back   My Verizon Users > The Basics > Basic Features
Basic Features Discuss basic features that are available on all phones here
Old 11-13-2007, 10:46 AM   #1 (permalink)
Default Caller ID & Caller ID Blocking
Description
<!-- mba_share_description_start --> Caller ID allows you to see the caller's phone number before you take the call. Caller ID may display the number of the person calling on your wireless phone (for all unblocked numbers). It may also display the name of the person if you've stored it in your phone's memory. Calls can usually be returned by pressing one button.
Caller ID Blocking
allows you to block your number from being displayed through Caller ID, and can either be done permanently or temporarily.
<!-- mba_share_description_end -->
How to Get It
Caller ID is an included feature that is typically added to your account when you first activate service. If you wish to confirm you have this feature, login to My Account and select "My Plan" and then select "Add/Change Features."
Caller ID Blocking must be activated; refer to the "How To Use It" Section below for instructions.
How to Use It
Caller ID
In order for Caller ID to work, the called party must:
1) Have a Caller ID-capable phone
2) Have the Caller ID feature activated
3) Be traveling in an area that supports Caller ID
Caller ID Blocking
To Deactivate Caller ID on individual outbound calls:
1) Press *67.
2) Dial the number.
3) Press SEND. The words "Private," "Anonymous," or some other indicator will appear on the called party's Caller ID device instead of your wireless number.
To Deactivate Caller ID on all calls to a specific number:
Press *82 + the number + SEND.
To permanently block your number from being displayed on any phone:
1) Login to My Account.
2) Click on the My Plan tab.
3) Click on Add/change features.
4) Check the box near "Caller ID Blocking."
5) Click the Next button at the bottom of the form.
Caller ID Alert? darrylk Motorola V750 0 10-18-2008 03:08 PM
How to save a picture as Caller ID on LG Chocolate 3 admin_mvu LG Chocolate 3 0 07-16-2008 11:46 AM
How to save PIX as Caller ID on LG Dare admin_mvu LG Dare 0 06-26-2008 02:58 PM
Restricted Caller mcnerd General Discussion 4 02-10-2007 08:14 AM
Sub LCD caller ID admin_mvu Official Verizon Rant Thread 2 09-05-2006 04:03 PM
