General Discussion Discuss general stuff here....
Old 12-16-2006, 02:47 PM   #1 (permalink)
aladavlis is on a distinguished road
Post problem with pc
Hello,
I am having trouble with my Internet explorer.It is doing some very odd things.Sometimes it will completely close the page i am visiting for no reason or it will be very slow loading pages and when i say slow i mean very very very slow for eg i tried to google something and after 10 minutes of the page trying to load i gave up.I thought that it was perhaps the topic i was searching so i tried putting in random things to see if that made any difference but it didn't.Another problem i had was when i was on a forum and clicked on a link and nothing happened i tried to open a new tab and that wouldn't work either and it would let me access any options that are in my tools menu.i had to restart my computer.Just to let you know i have high speed Internet connection.Thanks in advance to anyone that helps me with this problem.
aladavlis is offline   Reply With Quote
Old 12-16-2006, 11:45 PM   #2 (permalink)
It could be many different things that's causing the problem and hard to tell exactly what will fix it completely.
Few things to try -
- Run anti-virus and anti-spyware programs to remove anything in your PC that could be hogging the resources.
- Defragment your HD
- Remove bunch of programs that gets loaded automatically when you startup (look in your startup folder)
- Try using Firefox, instead of IE
Old 02-10-2007, 08:26 AM   #3 (permalink)
ClwTL will become famous soon enough
i agree with the firefox thing. to remove the files that auto start on your computer making it no less than 10 times faster go to start menu ->RUN-> type in msconfig -> click the top tab that says startup -> click disable all -> click apply -> click okay -> computer will restart and when it comes on a pop up will show asking if you want to change what you just did back. check the box saying never pop up with this message again and press okay. between that and firefox you should be set
ClwTL is offline   Reply With Quote
VCast Music Problem 757steve LG Dare 0 10-05-2008 03:39 PM
Problem with texting Twenty2hollister LG Dare 2 07-29-2008 01:09 PM
Problem LG Venus mjredd01 LG Venus 4 05-15-2008 07:34 AM
Samsung Flipshot SCHU900 Calendar Problem mitch449 Samsung FlipShot 1 05-07-2008 05:33 PM
USB 720 Card Instal Problem BBrad Wireless PC Cards 0 11-23-2007 02:47 PM
