Parse error: syntax error, unexpected T_STRING in /home/mvu/public_html/forums/global.php(607) : eval()'d code on line 1240
Battery Inserting / Removing - HTC DROID Incredible ADR6300 - My Verizon Users
Go Back   My Verizon Users > Verizon Phones > Smartphones > Discontinued Smartphones > HTC Incredible
HTC Incredible Discuss HTC Droid Incredible Here
Old 05-02-2010, 12:37 PM   #1
admin_mvu
Default Battery Inserting / Removing - HTC DROID Incredible ADR6300
Inserting the battery
Removing the battery
  1. Remove the back cover. Holding the phone with the touch screen facing down, lift up the back cover from the notch at the bottom of the device.
  2. Align the battery contacts with the contacts inside the battery compartment. Insert the contact side of the battery first then gently push the battery into place.
  3. Replace the back cover.
  1. Press and hold the Power button.
  2. Touch Power Off.
  3. Remove the back cover. Holding the phone with the touch screen facing down, lift up the back cover from the notch at the bottom of the device.
  4. Lift out the battery from the notch near the speaker.
Forum Jump
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
