Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG Chocolate 3
Old 07-14-2008, 04:22 PM   #1 (permalink)
Default How to send contacts via Bluetooth on LG Chocolate 3
Sending contacts via Bluetooth - LG Chocolate 3 (VX8560)
The receiving device must be able to support Bluetooth Object Push, have Bluetooth enabled and visible (for Bluetooth pairing). Please refer to the documentation that accompanied the receiving device for assistance with Bluetooth.
  3. Select Bluetooth Menu then cpress OK.
  4. Press the left soft key to choose Turn On.
    If the receiving device appears in the list (indicating that it has already been paired), skip to step 8.
  5. Ensure Add New Device then press OK.
  6. Ensure the receiving device is in discoverable mode (please refer to the manufacturer's user guide for additional assistance) then press OK.
  7. Select the desired Bluetooth device then press OK.
  8. Enter a passkey then press OK.
  9. Ensure the desired connection option is selected then press OK. Always Ask Prompts every time a connection is attempted Always Connect Automatically connects
  10. Select the desired Bluetooth device then press OK.
  11. Select Send Name Card then press OK.
  12. Select the desired contact(s), press OK to choose Mark then press the left soft key to choose Done.
    Up to 10 contacts can be selected per transfer.
How to send contacts via Bluetooth on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:01 PM
How to send contacts via Bluetooth on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:24 PM
How to send contacts via Bluetooth on LG Dare admin_mvu LG Dare 0 06-26-2008 02:46 PM
How to send contacts via Bluetooth on LG Decoy admin_mvu LG Decoy 0 06-17-2008 02:01 PM
How to send contacts via Bluetooth on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:08 AM
