Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG Chocolate 3
Old 07-14-2008, 05:24 PM   #1 (permalink)
Default How to enable / disable the auto save messaging feature on LG Chocolate 3
Enabling / disabling the auto save messaging feature - LG Chocolate 3 (VX8560)
  1. From the main screen, press the left soft key to choose Message.
  2. Press the left soft key to choose Settings.
  3. Select Auto Save then press OK.
  4. Ensure the desired setting is selected then press OK. On Enables the auto save feature. Off Disables the auto save feature. Prompt The handset will ask if the message is to be saved.
How to enable / disable auto save messaging feature on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 02:46 PM
How to enable / disable auto save messaging feature on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 09:14 PM
How to enable / disable auto save messaging feature on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 04:12 AM
How to enable / disable the auto save messaging feature on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 01:02 PM
How to enable / disable the auto save messaging feature on Samsung SCH-a930 admin_mvu Samsung a930 0 12-21-2007 05:03 PM
