Old 07-30-2008, 10:27 AM   #1 (permalink)
cdh12345 is on a distinguished road
Default How to put your Ringtones on the Dare
I just got the dare and worked very hard to figure out how to put my free ringtones on the Dare.
It is fairly simple and goes as follows
--Save the ringtones you want on your dare in "my sounds"
--From My sounds click on the name of the sound and a menu appears select send and send the sound to your self
--Once you get the message with the sound in the bottom hand corner there is a menu button; open the menu and select "save as rington"
--Thats it
cdh12345 is offline   Reply With Quote
Old 08-02-2008, 06:54 PM   #2 (permalink)
coom_Dare is on a distinguished road
ok so u can txt urself the tone form mysounds folder but whats the quickest and easiest way to put em in the mysounds folder?
coom_Dare is offline   Reply With Quote
Old 08-02-2008, 10:15 PM   #3 (permalink)
DeathRider is on a distinguished road
I used the latest version of bitpim and set phone to the VX-9100 (enV 2) and used bluetooth to transfer
DeathRider is offline   Reply With Quote
Old 08-16-2008, 09:00 PM   #4 (permalink)
Telegraph User
FA1SGL is on a distinguished road
Send a message via MSN to FA1SGL Send a message via Yahoo to FA1SGL
I have folders of ringtones and wallpapers on my PC and I use drag and drop to the folder(s) on the Dare using BitPim. Quick and simple.
FA1SGL is offline   Reply With Quote
How Dare they steal my Dare!!! michigan mobile LG Dare 7 09-18-2008 12:23 AM
BitPim and the Dare FA1SGL LG Dare 0 08-16-2008 11:43 PM
How to put custom ringtones in Motorola phones DeathGrind Motorola Phones 0 07-22-2008 09:51 PM
Ringtones on LG 8300 Help jjjordan14 LG VX8300 5 02-18-2007 08:43 AM
