Old 06-17-2008, 01:56 PM   #1 (permalink)
Default How to enable / disable the auto save messaging on LG Decoy
Enabling / disabling the auto save messaging feature - Decoy (LG VX8610)
  1. From the main screen, press the left soft key to choose Message.
  2. Press the left soft key to choose Settings to choose OK.
  3. Select Auto Save then press the center of the 5-way navigation pad to choose OK.
  4. Select the desired setting then press the center of the 5-way navigation pad to choose OK. On Enables the auto save feature. Off Disables the auto save feature. Prompt The handset will ask if the message is to be saved.
How to enable / disable auto save messaging feature on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:46 PM
How to enable / disable auto save messaging feature on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:14 PM
How to enable / disable auto save messaging feature on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 03:12 AM
How to enable / disable the auto save messaging feature on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 12:02 PM
How to enable / disable the auto save messaging feature on Samsung SCH-a930 admin_mvu Samsung a930 0 12-21-2007 04:03 PM
