Old 06-17-2008, 01:57 PM   #1 (permalink)
Default How to enable / disable standalone mode on LG Decoy
Enabling / disabling standalone mode - LG Decoy (VX8610)
The handset will not be able to make / receive phone calls or use any data service while the standalone mode is enabled.
  1. From the main screen, press the center of the 5-way navigation pad to Menu.
  2. Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
  3. Select Phone Settings then press the center of the 5-way navigation pad to choose OK.
  4. Select Standalone Mode then press the center of the 5-way navigation pad to choose OK.
  5. Select the desired setting then press the center of the 5-way navigation pad to choose OK.
    On Enables standalone mode. Off Disables standalone mode.
How to enable / disable standalone mode on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:37 PM
How to enable / disable Standalone Mode on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:24 PM
How to enable / disable standalone mode on Nokia 6205 admin_mvu Nokia 6205 0 06-17-2008 02:51 PM
How to enable / disable Music Only mode on LG Decoy admin_mvu LG Decoy 0 06-17-2008 02:03 PM
How to enable / disable Standalone mode on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:35 AM
