Old 06-17-2008, 01:58 PM   #1 (permalink)
Default How to create and send a TXT message on LG Decoy
Creating and sending a TXT message - LG Decoy (VX8610)
  1. From the main screen, press the left soft key to choose Message.
  2. Select New Message then press the center of the 5-way navigation pad to choose OK.
  3. Select TXT Message then press the center of the 5-way navigation pad to choose OK.
  4. Enter the 10-digit mobile number(s) or email address(s) in the numbered field(s) then press the center of the 5-way navigation pad.
    Up to ten recipients may be entered.
  5. Enter the desired text message in the Text: field.
    To add graphics, animations or sounds, press the right soft key to choose Options.
    1. Select Add then press the center of the 5-way navigation pad to choose OK.
    2. Select the desired category then press the center of the 5-way navigation pad to choose OK.
      • Graphic
      • Animation
      • Sound
    3. Select the desired item then press the center of the 5-way navigation pad to choose OK.
  6. Press the center of the 5-way navigation pad to choose Send.
How to create and send a PIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:08 PM
How to create and send a TXT message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:07 PM
How to create and send a TXT message on Boulder admin_mvu Casio G'zOne Boulder 0 08-03-2008 05:18 PM
How to create and send a PIX message on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:30 PM
How to create and send a PIX message on LG Decoy admin_mvu LG Decoy 0 06-17-2008 02:00 PM
