Old 06-17-2008, 02:00 PM   #1 (permalink)
Default How to create and send a PIX message on LG Decoy
Creating and sending a PIX message - LG Decoy (VX8610)
  1. From the main screen, press the camera key (located on the right side of the phone).
  2. Press the center of the 5-way navigation pad to choose Take.
  3. Press the center of the 5-way navigation pad to choose SEND.
  4. Enter the 10-digit mobile number(s) or email address(s) in the To: field then press the center of the 5-way navigation pad to choose OK.
  5. If desired, enter a text message in the Text field.
  6. If desired, add a Sound:
    1. Select the Sound: field then press the left soft key to choose Sounds.
    2. Select the desired sound then press the center of the 5-way navigation pad.
  7. If desired, add a Name Card:
    1. Select the Name Card: field then press the left soft key to choose Contacts.
    2. Select the desired Contact then press the center of the 5-way navigation pad.
  8. If desired, enter a subject in the Subject: field then press the center of the 5-way navigation pad to choose Send.
How to create and send a PIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:08 PM
How to create and send a TXT message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:07 PM
How to create and send a TXT message on Boulder admin_mvu Casio G'zOne Boulder 0 08-03-2008 05:18 PM
How to create and send a PIX message on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:30 PM
How to create and send a TXT message on LG Decoy admin_mvu LG Decoy 0 06-17-2008 01:58 PM
