01-03-2008, 05:45 PM
How to enable / disable auto save message feature on LG enV (VX9900)
Enabling / disabling the Auto Save message feature - LG enV (VX9900)- From the main screen, press the left soft key to choose Message.
- Select All Msg then press OK.
- Select Auto Save then press OK.
- Select the desired setting then press OK:
- Select On to enable the auto save feature.
- Select Off to disable the auto save feature.
- Select Prompt to have the handset ask if you want to save the message
