Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG enV
LG enV Discuss LG VX9900 enV Here
Old 01-03-2008, 05:48 PM   #1 (permalink)
Default How to format a memory card on LG enV (VX9900)
Formatting a memory card - LG enV (VX9900)
This procedure will erase all data on your card. It is recommended that you have a recent backup of your data; unless you are willing to lose it.
  3. Select Memory then press OK.
  4. Select Card Memory then press OK.
  5. Press the right soft key to choose Options.
  6. Select Format then press OK.
  7. When prompted, enter the 4-digit lock code.
    The default code is the last 4-digits of the mobile number.
  8. Select Yes then press OK.
The memory card will have the following folder structure:
  • my_music
  • my_flix
  • my_pix
  • my_sounds
How to format a memory card on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 02:52 AM
How do I format a memory card ? 1rlhtmma Casio G'zOne Boulder 4 09-19-2008 12:58 AM
How to format a memory card on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:34 PM
How to format a memory card on Motorola KRZR admin_mvu Motorola KRZR 0 12-21-2007 04:45 PM
