LG enV Discuss LG VX9900 enV Here
Old 02-15-2008, 12:39 PM   #1 (permalink)
GulliG is on a distinguished road
Default Brightness
Two seconds after turning on my enV the brightness goes dim and I have to hit a key to get it bright. Which then goes dim after 2 seconds. Any way to keep the display bright for longer than 2 seconds?
Thanks,
Duane
GulliG is offline   Reply With Quote
Old 02-15-2008, 03:09 PM   #2 (permalink)
There should be a menu option to change the time setting.
On my LG VX8600, Menu -> Settings and Tools -> Display Settings -> Backlight -> Display -> 3s / 5s / 10s / 20s / Always Off
