Formatting a memory card - LG enV2 (VX9100)
The LG enV2 (VX9100) uses a MicroSD card (up to 8 GB capacity).
This procedure will erase all data on the memory card. It is recommended to back up the data.
- With the phone open and from the main screen, press OK to choose Menu.
- Select Settings & Tools then press OK.
- Select Memory then press OK.
- Select Card Memory then press OK.
- Press the right soft key to choose Options.
- Select Format then press OK.
- When prompted, enter the 4-digit lock code.
The default code is the last 4-digits of the mobile number.
- Select Yes then press OK.
The memory card will have the following folder structure:
- my_music
- my_flix
- my_pix
- my_sounds
