06-05-2008, 11:08 AM
How to enable / disable auto signature on LG enV2
Enabling / disabling auto signature - LG enV2 (VX9100)
- With the phone open and from the main screen, press the left soft key to choose Message.
- Select Signature then press OK.
- From the Signature screen, make the desired changes:
- Select None to disable the auto signature then press OK.
- Select Custom, enter a signature to enable the auto signature then press OK to choose Save.
