Go Back   My Verizon Users > Verizon Phones > LG Phones > LG enV2
LG enV2 Discuss LG enV2 (VX9100) Here
Old 06-05-2008, 11:08 AM   #1 (permalink)
Default How to send contacts via Bluetooth on LG enV2
Sending contacts via Bluetooth - LG enV2 (VX9100)
The receiving device must be able to support Bluetooth Object Push, have Bluetooth enabled and visible (for Bluetooth pairing). Please refer to the documentation that accompanied the receiving device for assistance with Bluetooth.
  1. With the phone open and from the main screen, press OK to choose Menu.
  3. Select Bluetooth Menu then press OK.
    If the receiving device appears in the list (indicating that it has already been paired), skip to step 8.
  4. Select Add New Device then press OK.
    If prompted to turn Bluetooth on, select Yes then press OK.
  5. Select the desired Bluetooth device then press OK to choose Pair.
  6. Enter the passkey (the default passkey is 0000).
  7. When prompted, select either Always Ask (to be prompted every time a connection to the target device is attempted) or Always Connect then press OK.
  8. Select the desired Bluetooth device then press the right soft key to choose Options.
  9. Select Send Name Card then press OK.
  10. Select the desired contact(s) then press OK to choose Mark.
    Up to 10 contacts can be selected per transfer.
  11. Press the left soft key to choose Done.
How to send contacts via Bluetooth on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:01 PM
How to send contacts via Bluetooth on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:24 PM
How to send contacts via Bluetooth on LG Chocolate 3 admin_mvu LG Chocolate 3 0 07-14-2008 04:22 PM
How to send contacts via Bluetooth on LG Dare admin_mvu LG Dare 0 06-26-2008 02:46 PM
How to send contacts via Bluetooth on LG Decoy admin_mvu LG Decoy 0 06-17-2008 02:01 PM
