Go Back   My Verizon Users > Verizon Phones > LG Phones > LG enV2
LG enV2 Discuss LG enV2 (VX9100) Here
Old 06-05-2008, 11:10 AM   #1 (permalink)
Default How to adjust the camera on LG enV2
Adjusting the camera settings - LG enV2 (VX9100)
  1. Press the camera key (located on the left side of the device) then open the device.
    Press and hold the camera key to enter video mode.
  2. Press the right soft key to choose Options.
  3. Select the desired option:
    • Resolution
    • Self Timer
    • White Balance
    • Shutter Sounds
    • Color Effect
    • Night Mode
    • Save Location
    • Photometry
    • External Display
    • Capture Mode
Resolution
From the options bar, select the Resolution icon, select the desired setting then press OK.
  • 1600x1200
    Pictures taken with this resolution setting cannot be sent as a picture message.
  • 1280x960
  • 640x480
  • 320x240
Self Timer
From the options bar, select the Self Timer icon, select the desired setting then press OK.
  • Off
  • 3 seconds
  • 5 seconds
  • 10 seconds
White Balance
From the options bar, select the White Balance icon, select the desired setting then press OK.
  • Auto
  • Sunny
  • Cloudy
  • Fluorescent
  • Glow
Shutter Sounds
From the options bar, select the Shutter Sounds icon, select the desired setting then press OK.
  • Shutter
  • No Sound
  • Say "Cheese"
  • Ready! 1-2-3
Color Effects
From the options bar, select the Color Effects icon, select the desired setting then press OK.
  • Normal
  • Negative
  • Aqua
  • Sepia
  • Black & White
Night Mode
From the options bar, select the Night Mode icon, select the desired setting then press OK.
  • On
  • Off
Save Location
From the options bar, select the Save Location icon, select the desired setting then press OK.
  • Internal
  • External
Photometry
From the options bar, select the Photometry icon, select the desired setting then press OK.
  • Average
  • Spot
External Display
From the options bar, select the External Display icon, select the desired setting then press OK.
  • On
  • Off
Capture Mode
From the options bar, select the Capture Mode icon, select the desired setting then press OK.
  • Camera
  • Video
How to adjust the camera settings on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:56 PM
How to adjust the camera settings on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:39 PM
How to adjust the camera setting on Blitz admin_mvu Verizon Wireless Blitz 0 08-25-2008 09:06 AM
How to adjust the camera settings on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:20 PM
How to adjust the camera on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:39 PM
