Go Back   My Verizon Users > Verizon Phones > LG Phones > LG enV2
LG enV2 Discuss LG enV2 (VX9100) Here
Old 06-05-2008, 11:23 AM   #1 (permalink)
Default How to create and send a TXT message on LG enV2
Creating and sending a TXT message - LG enV2 (VX9100)
  1. With the phone open and from the main screen, press the left soft key to choose Message.
  2. Select New Message then press the center of the navigation pad to choose OK.
  3. Select TXT Message then press the center of the navigation pad to choose OK.
  4. Enter the desired 10-digit mobile number(s) or email address(s) in the To: fields(s) then press the center of the navigation pad to choose OK.
  5. Enter the desired text message.
  6. To add a graphic, animation or sound, press the right soft key to choose Options.
    1. Select Add then press the center of the navigation pad to choose OK.
    2. Select the desired category (Graphic, Animation or Sound) then press the center of the navigation pad to choose OK.
    3. Select the desired item then press the center of the navigation pad to choose OK.
  7. Press the center of the navigation pad to choose Send.
How to create and send a PIX message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:08 PM
How to create and send a TXT message on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:07 PM
How to create and send a TXT message on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:27 PM
How to create and send a FLIX message on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:37 AM
How to create and send a PIX message on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:36 AM
