Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG enV2
LG enV2 Discuss LG enV2 (VX9100) Here
Old 06-05-2008, 11:26 AM   #1 (permalink)
Default How to enable / disable handset restriction on LG enV2
Enabling / disabling handset restrictions - LG enV2 (VX9100)
  1. With the phone open and from the main screen, press OK to choose Menu.
  3. Select Phone Settings then press OK.
  4. Select Security then press OK > OK.
  5. Enter the 4-digit lock code (typically the last four digits of the phone number).
  6. Select Restrictions then press OK.
  7. Enter the 4-digit service code (typically the last four digits of the phone number).
  8. Select the desired feature then press OK.
    Location Setting
    Calls
    Messages
    Dial-up Modem
Location Setting
Lock Setting Enables Location Settings password protection Unlock Setting Disables Location Settings password protection Calls
Incoming Calls
Allow All Enables all incoming calls Contacts Only Enables incoming calls from contacts only Block All Disables all incoming calls Outgoing Calls
Allow All Enables all outgoing calls Contacts Only Enables outgoing calls from contacts only Block All Disables all outgoing calls Messages
Incoming Messages
Allow All Enables incoming messages Block All Disable incoming messages Outgoing Messages
Allow All Enables outgoing messages Block All Disable outgoing messages Dial-up Modem
Allow All Enables dial-up modem function Block All Disables dial-up modem function
How to enable / disable handset restriction on Samsung u430 admin_mvu Samsung u430 0 10-03-2008 11:56 AM
How to enable / disable Standalone mode on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:35 AM
How to enable / disable Music Only mode on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:27 AM
How to enable / disable Bluetooth on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:22 AM
How to enable / disable handset restriction on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:41 PM
