Go Back   My Verizon Users > Verizon Phones > LG Phones > LG enV2
LG enV2 Discuss LG enV2 (VX9100) Here
Old 06-05-2008, 11:28 AM   #1 (permalink)
Default How to enable / disable GPS location on LG enV2
Enabling / Disabling GPS location - LG enV2 (VX9100)
  1. With the phone open and from the main screen, press OK to choose Menu.
  3. Select Phone Settings then press OK.
  4. Select Location then press OK.
  5. Select the desired setting then press OK.
    Location On Enables GPS location E911 Only Disables GPS location
How to enable / disable GPS location on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 12:01 PM
How to enable / disable GPS Location on Nokia 6205 admin_mvu Nokia 6205 0 08-09-2008 03:57 PM
How to enable / disable GPS location on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:32 PM
How to enable / disable GPS location on LG Dare admin_mvu LG Dare 0 06-26-2008 02:57 PM
How to enable / disable handset restriction on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:26 AM
