Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG enV2
LG enV2 Discuss LG enV2 (VX9100) Here
Old 06-05-2008, 12:31 PM   #1 (permalink)
Default How to save PIX as wallpaper on LG enV2
Saving PIX as wallpaper - LG enV2 (VX9100)
  1. With the phone open and from the main screen, press OK to choose Menu.
  2. Select Media Center then press OK.
  3. Select Picture & Video then press OK.
  4. Select My Pictures then press OK.
  5. Select the desired Picture then press the right soft key to choose Options.
  6. Select Set As then press OK.
  7. Select Wallpaper then press OK.
  8. Select the desired setting then press OK:
    • Internal Wallpaper.
    • External Wallpaper.
Old 08-16-2008, 11:38 PM   #2 (permalink)
Telegraph User
FA1SGL is on a distinguished road
Send a message via MSN to FA1SGL Send a message via Yahoo to FA1SGL
BitPim version 1.0.6 supports the EnV.
Download BitPim and find the folder that contains your pictures..as I have a Dare the folders might be different but the structure should be the same. For the Dare once you connect your phone by clicking the find phone link click filesystem on the left pane once your files are detected open the brew folder, open the mod folder..folder 10888 is for pics and 10889 is for ringtones. Open explorer and go to the folder where you have your pics, select and drop in to the pane on the right that appears when you open folder 10888. Again those are the folders for the Dare but as the EnV is also an LG the structure and names most likely are the same.
FA1SGL is offline   Reply With Quote
How to save FLIX as wallpaper on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 09:04 PM
How to save PIX as Wallpaper on LG Chocolate 3 admin_mvu LG Chocolate 3 0 07-16-2008 12:55 PM
How to save a PIX / FLIX message on LG enV2 admin_mvu LG enV2 0 06-05-2008 12:38 PM
How to save FLIX as wallpaper on LG enV2 admin_mvu LG enV2 0 06-05-2008 12:24 PM
How to enable / disable the auto save message feature on LG enV2 admin_mvu LG enV2 0 06-05-2008 12:07 PM
