06-05-2008, 11:36 AM
How to create and send a PIX message on LG enV2
Creating and sending a PIX message - LG enV2 (VX9100)
- Press the camera key (located on the left side of the device) then open the device.
- Aim then press OK to Take the picture.
- Press OK to chooseSend.
- Enter the 10-digit mobile number or email address in the To: field then press OK.
- Add Text to the message, if desired.
- Add a Sound to the message, if desired.
- Select the Sound: field then press the left soft key.
- Select the desired sound then press OK.
- Add a Subject to the message, if desired.
- Press OK to choose Send.
