Originally Posted by MaxRide
I found the drivers...but it said there was a problem with registering...and it doesn't work. What do I do now?
I found a website that has the drivers for the LG VX8350 that will work with BitPim for those interested. You can find them at:
http://www.wirelessemporium.com/prod...sp?relatedid=0
The driver doesn't install on Windows Vista unless you do the following.
After downloading and unzipping the driver file right click setup.exe, click "Properties", click the "Compatibility" tab, check box for "Run this program in compatibility mode for:” In the drop down box choose the appropriate operating system. Then double click setup.exe to run the program and install the drivers.
It works perfect for me on my Windows Vista Ultimate machine.
