Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG VX8350
LG VX8350 Discuss LG VX8350 Here
Old 07-11-2008, 03:29 AM   #1 (permalink)
Unhappy in Austin
Guest
Posts: n/a
Default Audio Dropoff; chronic problem
I am having a chronic problem with the VX8350. During a call, there are intermittent periods of up to a minute when I cannot hear the caller. The call is not dropped, but the volume drops so low I cannot understand what is being said. It occurs regardless of location (happening both in SE Austin and on MoPac), regardless of caller (happened on a 611 warranty call) and regardless of output device used (headset, handset, speaker). I have been through 8 phones, and this is still happening.
The store wants to put the current unit on a test bench, but I have no confidence they will actually do this. I think they are looking for a way to get rid of me. Any way I can get the actual data from the test bench diagnostic to see what is going on?
Any ideas/suggestions? They've offered me the VX8700, which is almost out of stock as a replacement, which I'm not happy with.
Old 07-11-2008, 08:24 AM   #2 (permalink)
It sounds like a bad phone. Take the replacement phone. If you don't like VX8700, ask them for a different phone.
Old 07-20-2008, 08:55 PM   #3 (permalink)
Banned
vzwdallas is on a distinguished road
maybe a sw bug. Call *611 ask if there is an update out. Go to a VZW store ask them to flash ur sw
vzwdallas is offline   Reply With Quote
Old 07-22-2008, 07:55 PM   #4 (permalink)
joe4508 is on a distinguished road
I had this problem also at first. But this may fix it for you. goto MENU, SETTINGS & TOOLS, SOUND SETTINGS, 7 VOICE CLARITY, and turn it OFF. If your environment changes from quiet to noisey or back it takes the noise filters a little bit to catch up. With this turned off it doesn't try and should eliminate the voice dropout
joe4508 is offline   Reply With Quote
Old 08-29-2008, 03:49 PM   #5 (permalink)
ilikeverizon12 will become famous soon enough
The 8360 should be out soon, or if you can't wait, the Chocolate 3 is out, and only like $149. Go for it!
ilikeverizon12 is offline   Reply With Quote
VCast Music Problem 757steve LG Dare 0 10-05-2008 03:39 PM
Problem with texting Twenty2hollister LG Dare 2 07-29-2008 01:09 PM
Problem LG Venus mjredd01 LG Venus 4 05-15-2008 07:34 AM
Samsung Flipshot SCHU900 Calendar Problem mitch449 Samsung FlipShot 1 05-07-2008 05:33 PM
problem with pc aladavlis General Discussion 2 02-10-2007 08:26 AM
