Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG VX8550
LG VX8550 Discuss LG VX8550 Here
Old 12-21-2007, 03:51 PM   #1 (permalink)
Default How to format a memory card on LG Chocolate (VX8550)
Formatting a memory card - LG Chocolate (VX8550)
This procedure will erase all data on your card. It is recommended that you have a recent backup of your data; unless you are willing to lose it.
  1. With the handset open and from the main screen, press the center of the 5-way navigation pad to choose Menu.
  2. Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
  3. Select Memory then press the center of the 5-way navigation pad to choose OK.
  4. Select Card Memory then press the center of the 5-way navigation pad to choose OK.
  5. Press the right soft key to choose Options.
  6. Select Format Card then enter the Lock Code for the device.
    The default code is the last 4-digits of the mobile number.
  7. Select Yes then press OK.
How to format a memory card on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 02:52 AM
How do I format a memory card ? 1rlhtmma Casio G'zOne Boulder 4 09-19-2008 12:58 AM
How to format a memory card on LG Chocolate 3 admin_mvu LG Chocolate 3 0 07-16-2008 11:56 AM
How to format a memory card on Motorola KRZR admin_mvu Motorola KRZR 0 12-21-2007 04:45 PM
