Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG VX8550
LG VX8550 Discuss LG VX8550 Here
Old 12-28-2007, 09:54 AM   #1 (permalink)
Default How to put your ringtones on LG Chocolate (VX8550)
The following is how to put ringtones on your LG VX8550.USB:
  • Install drivers from the Music Essentials Kit or install the VCast Music Manger from here: V CAST Music Manager Download
  • Plug the phone in
  • Start BitPim - Edit > Settings > Browse. Make sure the 'LGE CDMA USB Serial Port' is the port being used in the com port field.
  • Set the phone type to LG-VX8550 - Get Phone Data
  • Go to Filesystem (if you don't have the Filesystem link then View > Show Filesystem), expand it, and navigate to /brew/mod/10889/ringtones , right click in the ringtones folder and select "New" - browse to your ringtone and click "ok"
  • Restart the phone.
Nothing other than the Filesystem tab will work unless the phone is supported as an option under "phonetype".
Bluetooth:
  • This is similar to the above but first you must pair the phone and pc and get the Serial BT DIAG profile to connect one time.
  • With widcomm drivers you have "My Bluetooth Places" - go there and double click on the icon representing your phone.
  • Double click the BT DIAG icon to connect.
  • Take note of the com port that this connection uses (right click on the BT DIAG icon to see the port).
  • Use this in the com port field in BitPim
  • Follow the instructions for USB.
If you have some other Bluetooth drivers the process should be similar.
Chocolate 3 and Bitpim (do ringtones work?) OregonTrail LG Chocolate 3 3 09-03-2008 08:09 PM
How to set ringtones on LG Chocolate 3 admin_mvu LG Chocolate 3 0 07-16-2008 11:53 AM
How to synchronize music on LG Chocolate (VX8550) admin_mvu LG VX8550 0 12-21-2007 03:53 PM
How to format a memory card on LG Chocolate (VX8550) admin_mvu LG VX8550 0 12-21-2007 03:51 PM
