Go Back   My Verizon Users > Verizon Phones > LG Phones > Discontinued LG Phones > LG VX8600
LG VX8600 Discuss LG VX8600 Here
Old 01-18-2007, 11:06 PM   #1 (permalink)
Default How to use ringers from the SD card on VX 8600
Transferring files to the microSD card through the phone using BitPim is very slow, users should transfer ringers to the card directly from a PC.
1. On the microSD card, create a subdir called ringers (all lowercase)
2. Copy your ringtone files to the ringers subdir.
3. Insert the card back into the phone and start BitPim.
4. Retrieve Ringtone data from the phone:
1. Menu Data -> Get Phone Data.
2. Check on Ringtone, and click on OK.
5. Write Ringtone data back to the phone:
1. Menu Data -> Send Phone Data.
2. Check on Ringtone and Replace All, and click on OK.
6. All of the ringtones stored on both the phone and the card are now available for assignment.
Step 3 through 5 should be repeated for all changes made to the ringers subdir.
Ringtones stored on the microSD card will not show up in the Ringers tab, since BitPim does not add or delete those files.
Old 01-20-2007, 08:59 AM   #2 (permalink)
Telephone User
buddude1980 is on a distinguished road
were do i get bitpim
buddude1980 is offline   Reply With Quote
Old 01-20-2007, 09:03 AM   #3 (permalink)
At bitpim.org.
How to insert / remove a memory card on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 02:54 AM
How to insert and remove a memory card on Palm Centro admin_mvu Palm Centro 0 06-17-2008 02:59 PM
PC Card FAQ admin_mvu Wireless PC Cards 0 01-02-2008 09:55 PM
