01-03-2008, 05:42 PM
How to enable / disable auto save message feature on LG VX8700
Enabling / disabling the Auto Save message feature - LG VX8700- From the main screen, press the left soft key to choose Message.
- Select All Messages then press OK.
- Select Auto Save then press OK.
- Select the desired setting then press OK:
- Select On to enable the auto save feature.
- Select Off to disable the auto save feature.
- Select Prompt to have the handset ask if you want to save the message.
