Formatting a memory card - LG VX9400
This procedure will erase all data on your card. It is recommended that you have a recent backup of your data; unless you are willing to lose it.
- Swivel the display into landscape mode.
- From the main screen, press OK to choose Menu.
- Select Settings & Tools then press OK.
- Select Memory then press OK.
- Select Card Memory then press OK.
- Press the right soft key to choose Options.
- Select Format Card then press OK.
- When prompted to Enter Lock Code, enter the 4-digit lock code.
The default code is the last 4-digits of the mobile number.
- Select Yes then press OK.
