LG VX9400 Firmare vs.3 released
- Fixed issue of calendar freezing on device
- While in a phone call, the reminder vibrates in case it has set to do so. As a consequence, it interrupts the conversation on both sides
- Fixed MMS issue “Message Expired or Not Available”
- Fixed the problem when the phone is in manner mode, the beep alert is played for a received msg/voicemail during a call but afterwards the reminder is vibrated
- Updates to MediaFLO (V CAST Mobile TV) application
- Fixed the problem that the handset couldn't display the number about a Digital Numeric Page
- When setting the Pix Alert to no ring and vibrate mode is turned on, there is no ring and no vibration of the phone, when a Pix message is received
- Added functionality - If the MMS message contains embedded URLs, the user will have the option to go directly to a URL via launching the browser
Your local store should have this update.
