Free iPad 3
Go Back   My Verizon Users > Verizon Phones > Smartphones > Discontinued Smartphones > Motorola DROID
Motorola DROID Discuss Motorola DROID Here
Old 11-15-2009, 12:44 AM   #1 (permalink)
Default How to Perform a hard reset - Motorola Droid (A855)
Performing a hard reset - Motorola Droid (A855)
Performing a hard reset will remove ALL data including the Google account, system data, application data, application settings, and downloaded applications. Only perform this reset if absolutely necessary.
Preferred method
Alternate method
Preferred method
  1. From the home screen, touch the applications tab (located on the bottom of the screen).
  2. Touch Settings.
  3. Touch Privacy.
  4. Touch Factory data reset.
  5. Touch Reset phone.
  6. Touch Erase Everything.
Alternate Method
  1. With the device powered off, slide the keyboard open.
  2. Press the Power key and the X key simultaneously, until the Recovery screen appears.
  3. Press the Volume up key and the Camera key simultaneously, to show the Recovery menu.
  4. Using the Volume keys, select Wipe data factory Reset.
  5. Press the center of 5-way navigation pad.
  6. Using the Volume keys, select Yes -- delete all user data.
  7. Press the center of 5-way navigation pad.
  8. Using the Volume keys select Reboot system now.
  9. Press the center of 5-way navigation pad.
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
