Inserting / removing a memory card - Motorola Krave ZN4
The Motorola Krave ZN4 supports up to 8 GB microSD (TransFlash) memory card. A memory card is not included with your phone but can be purchased from any Verizon Wireless
retail store or at the
online store.
Inserting a memory card:
- Press the red Power (End) key to turn the phone off.
- With the metal pins facing down, slide the memory card into the card slot until it clicks in place.
Removing a memory card:
To avoid damage to the memory card, do not remove while storing or moving data.
- Press in on the memory card until it clicks, then pull the memory card out of the card slot.
