Formatting a memory card - Motorola KRZR
When formating the memory card all data on the card will be permanently removed. Format the card ONLY if the files on the card are unwanted or if they are backed up.
Refer to the documentation that accompanied the memory card for the proper method to format the card.
Setting up the folder structure:- Place the TransFlash card into the memory card slot (located in the battery compartment).
- Turn the phone off.
- Turn the phone on.
The memory card will have the following folder structure:
- my_music
- my_flix
- my_pix
- my_sounds
