Old 05-23-2008, 05:03 PM   #1 (permalink)
Default How to perform a hard reset on Motorola Q9m
Performing a hard reset - Motorola Q / Q9m
A hard reset is the last resort for troubleshooting. This reset will erase all data and restore preferences to factory default specifications. Performing a hard reset is only recommended when the existing data has been backed up or is unwanted.
If the preferred method is not available, there is an Alternate Method.
Preferred Method
  2. Select System Tools then press the center of the 5-way navigation pad.
  3. Select Master Reset then press the center of the 5-way navigation pad.
  4. Press the left soft key to choose Yes.
Alternate method
To perform this reset software versions: Q2-BP_C_06.07.03P (or later) & MP_BSP_C_02.07.38-11P_HW_P2.1(or later) are required. To verify current version, tap Start> Settings> More...> More...> Phone Settings> Phone Information.
The Motorola Q9m has the appropriate software version.
  1. Power off the device.
  2. Press and hold the center of the 5-way navigation pad then press the power key.
  3. Release the center of the 5-way navigation pad when the Master Reset prompt appears.
How to perform a hard reset on Samsung Omnia admin_mvu Samsung Omnia 0 12-20-2008 10:12 PM
How to perform a hard reset on Samsung Saga admin_mvu Samsung Saga 0 11-16-2008 07:48 PM
How to perform a hard reset on Palm Centro admin_mvu Palm Centro 0 06-17-2008 02:58 PM
How to perform a soft reset on Motorola Q9m admin_mvu Motorola Q9m 0 05-23-2008 05:05 PM
How to perform a hard reset on Palm Treo 755P admin_mvu Palm Treo 755P 0 12-28-2007 04:33 PM
