Formatting a memory card - Motorola Rapture VU30
The Motorola Rapture VU30 uses a MicroSD card (up to 8GB capacity).
This procedure will erase all data on the memory card. It is recommended to backup the data before proceeding.
- From the main screen, press the center of the 5-way navigation pad to choose Menu.
- Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
- Select Memory then press the center of the 5-way navigation pad to choose OK.
- Select Card Memory then press the center of the 5-way navigation pad to choose OK.
- Select Format Card then press the center of the 5-way navigation pad to choose OK.
- If prompted, enter the 4-digit lock code.
The default code is the last 4-digits of the mobile number.
- Select Yes then press the center of the 5-way navigation pad to choose OK.
The memory card will have the following folder structure:
- Motorola
- my_flix
- my_music
- my_pix
- my_sounds
