Go Back   My Verizon Users > Verizon Phones > Motorola Phones > Motorola Rapture VU30
Motorola Rapture VU30 Discuss Motorola Rapture VU30 Here
Old 11-01-2008, 11:24 PM   #1 (permalink)
Default How to send contacts via Bluetooth on Motorola Rapture VU30
Sending contacts via Bluetooth - Motorola Rapture VU30
The receiving device must be able to support Bluetooth Object Push, have Bluetooth enabled and paired.
  1. From the main screen, press the right soft key to choose Contacts.
  2. Select the desired contact then press the right soft key to choose Options.
  3. Select Send Name Card then press the center of the 5-way navigation pad to choose OK.
  4. Select Bluetooth then press the center of the 5-way navigation pad to choose OK.
  5. If sending one contact, press the center of the 5-way navigation pad to choose SEND.
    To send more than one contact, press the right soft key to choose Add.
    1. Select the desired option then press the center of the 5-way navigation pad to choose OK.
      Add Multiple Allows to add several contacts Add All Adds all contacts to be sent
    2. If Add Multiple was selected, select the desired contacts by pressing OK for each contact then press the left soft key to choose Done.
    3. Press the the center of the 5-way navigation pad to choose Send.
  6. Select the desired receiving device then press the center of the 5-way navigation pad to choose OK.
How to enable / disable Bluetooth discovery mode on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:30 PM
How to send a picture to the Online Album on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:26 PM
How to enable / disable Bluetooth on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:25 PM
How to send contacts via Bluetooth on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 02:53 AM
How to save contacts via Bluetooth on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:27 PM
