Go Back   My Verizon Users > Verizon Phones > Motorola Phones > Motorola Rapture VU30
Motorola Rapture VU30 Discuss Motorola Rapture VU30 Here
Old 11-01-2008, 11:25 PM   #1 (permalink)
Default How to move audio files to / from the memory card on Motorola Rapture VU30
Moving audio files to / from the memory card - Motorola Rapture VU30
  2. Select Media Center then press the center of the 5-way navigation pad to choose OK.
  3. Select Music & Tones then press the center of the 5-way navigation pad to choose OK.
  4. Select My Music then press the center of the 5-way navigation pad to choose OK.
  5. Select Songs then press the center of the 5-way navigation pad to choose OK.
  6. Select the desired song then press the right soft key to choose Options.
  7. Select Move song then press the center of the 5-way navigation pad to choose OK.
    Depending upon where the file is being moved from, select the desired option:
    • Move song to memory card?
    • Move song to phone memory?
  8. Select Yes then press the center of the 5-way navigation pad to choose OK.
How to move audio files to / from the memory card on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:03 PM
How to format a memory card on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:23 PM
How to insert / remove a memory card on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 03:20 PM
How to move picture files to and from the memory card on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:31 PM
How to move audio files to / from the memory card on LG enV2 admin_mvu LG enV2 0 06-05-2008 11:29 AM
