Go Back   My Verizon Users > Verizon Phones > Motorola Phones > Motorola Rapture VU30
Motorola Rapture VU30 Discuss Motorola Rapture VU30 Here
Old 11-01-2008, 11:27 PM   #1 (permalink)
Default How to create and send a TXT message on Motorola Rapture VU30
Creating and sending a TXT message - Motorola Rapture VU30
  1. From the main screen, press the left soft key to choose Message.
  2. Select New Message then press the center of the 5-way navigation pad to choose OK.
  3. Select TXT Message then press the center of the 5-way navigation pad to choose OK.
  4. Enter the 10-digit mobile number(s) or email address(s) in the numbered field(s) then press the center of the 5-way navigation pad to choose OK.
    Up to ten recipients may be entered.
  5. Enter the desired text message in the Text: field.
    To add graphics, animations or sounds, press the right soft key to choose Options.
    1. Select the desired category then press the center of the 5-way navigation pad to choose OK.
      • Add Graphic
      • Add Sound
    2. Select the desired item then press the center of the 5-way navigation pad to choose OK.
  6. Press the center of the 5-way navigation pad to choose Send.
How to create and send a PIX message on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:33 PM
How to create and send a picture message on Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 03:00 AM
How to create and send a PIX message on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:30 PM
How to create and send a TXT message on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:26 PM
How to create and send a video message on Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:22 PM
