Go Back   My Verizon Users > Verizon Phones > Motorola Phones > Motorola Rapture VU30
Motorola Rapture VU30 Discuss Motorola Rapture VU30 Here
Old 11-01-2008, 11:30 PM   #1 (permalink)
Default How to lock / unlock Motorola Rapture VU30
Locking and unlocking the wireless device - Motorola Rapture VU30
The Phone Lock feature, helps prevent unauthorized use of the device by disabling outbound data and voice calls. The device will still be able to receive phone calls and place emergency calls to 9-1-1.
To lock the phone:
  2. Select Settings & Tools thenpress the center of the 5-way navigation pad.
  3. Select Phone Settings thenpress the center of the 5-way navigation pad.
  4. Select Security thenpress the center of the 5-way navigation pad.
  5. Enter the Phone Lock Code.
    The default lock code is the last 4-digits of the mobile number.
  6. Select Lock Phone Now thenpress the center of the 5-way navigation pad.
    To enable / disable the phone lock when the device is powered on:
    1. Select Phone Lock thenpress the center of the 5-way navigation pad.
    2. Set as desired thenpress the center of the 5-way navigation pad: Unlock The phone is never locked (lock mode can be used). On Power Up The phone is locked when it is turned on.
To unlock the phone:
  1. Press the right soft key to choose Unlock.
  2. Enter the Phone Lock Code
How to enable / disable handset restrictions on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:31 PM
How to format a memory card on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:23 PM
How to insert / remove a memory card on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 03:20 PM
How to lock / unlock Motorola Krave ZN4 admin_mvu Motorola Krave ZN4 0 10-31-2008 03:00 AM
How to lock and unlock Motorola V750 admin_mvu Motorola V750 0 08-01-2008 09:21 PM
