Go Back   My Verizon Users > Verizon Phones > Motorola Phones > Motorola Rapture VU30
Motorola Rapture VU30 Discuss Motorola Rapture VU30 Here
Old 11-01-2008, 11:31 PM   #1 (permalink)
Default How to enable / disable handset restrictions on Motorola Rapture VU30
Enabling / disabling handset restrictions - Motorola Rapture VU30
  2. Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
  3. SelectPhone Settings then press the center of the 5-way navigation pad to choose OK.
  4. Select Securitythen press the center of the 5-way navigation pad to choose OK.
  5. Enter the Phone Lock Code (typically the last four digits of the phone number).
  6. Select Restrictions then press the center of the 5-way navigation pad.
  7. Enter the Service Lock Code (typically the last four digits of the phone number).
  8. Select the desired option then press the center of the 5-way navigation pad.
    Location Setting
    Lock Setting: Enables Location Settings password protection. Unlock Setting: Disables Location Settings password protection.
    Calls Incoming Calls Allow All: Enables all incoming calls. Contacts Only: Enables incoming calls from contacts only. Block All: Disables all incoming calls. Outgoing Calls Allow All: Enables all outgoing calls. Contacts Only: Enables outgoing calls from contacts only. Block All: Disables all outgoing calls.
    Messages Incoming Messages Allow All: Enables incoming messages. Block All: Disables incoming messages. Outgoing Messages Allow All: Enables outgoing messages. Block All: Disables outgoing messages
    Dial-Up Modem Allow All: Enables incoming messages. Block All: Disables incoming messages.
How to enable / disable standalone mode on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:37 PM
How to enable / disable auto save messaging feature on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:33 PM
How to enable / disable Bluetooth discovery mode on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:30 PM
How to enable / disable auto signature on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:29 PM
How to enable / disable speakerphone on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:24 PM
