11-01-2008, 11:33 PM
How to enable / disable auto save messaging feature on Motorola Rapture VU30
Enabling / disabling the auto save messaging feature - Motorola Rapture VU30
- Select Auto Save then press the center of the 5-way navigation pad to choose OK.
- Select the desired setting then press the center of the 5-way navigation pad to choose OK.
On Enables the auto save feature. Off Disables the auto save feature. Prompt The handset will ask if the message is to be saved.
