Enabling / disabling standalone mode - Motorola Rapture VU30
The handset will not be able to make / receive phone calls or use any data service while the standalone mode is enabled.
- From the main screen, press the center of the 5-way navigation pad to choose Menu.
- Select Settings & Tools then press the center of the 5-way navigation pad to choose OK.
- Select Phone Settings then press the center of the 5-way navigation pad to choose OK.
- Select Standalone Mode then press the center of the 5-way navigation pad to choose OK.
- Select the desired setting then press the center of the 5-way navigation pad to choose OK.
On Enables standalone mode. Off Disables standalone mode.
