There are several options to personalize your phone. Below is a list of these options and its description.
To access these features:- Press Menu (Center Select Key).
- Scroll to and Select Settings & Tools.
- Scroll to and Select Display Settings.
- Scroll to and Select the desired field.
Banner: Set a heading to display on your screen.
Wallpaper: Set a photo, picture, or animation as a wallpaper (background).
Screen Saver: Set a photo, picture, or animation as a screen saver. The screen saver displays when the flip is open and no activity is detected for a set time.
Tip: This feature helps save your screen, but not your battery. To extend battery life, turn off the screen saver.
Backlight: Set how long the backlights for the home screen and the keypad remain on, or turn off backlights to extend battery life.
Tip: Setting Backlight to Always On will reduce battery life significantly and require more frequent battery charging.
Brightness: Set the brightness of your screen.
Clock Format: Set how your phone shows the current time on the home screen and on the external display:ustomize the message that displays during power up.
