Go Back   My Verizon Users > Verizon Phones > Motorola Phones > Motorola V750
Motorola V750 Discuss Motorola V750 Here.
Old 08-01-2008, 09:20 PM   #1 (permalink)
Default How to adjust the camera settings on Motorola V750
Adjusting the camera settings - Motorola Adventure V750
  1. From the main screen, press the camera key (located above the green Send key).
  2. Press the right soft key to choose Options.
  3. Select the desired option then press OK.
    • Resolution
    • Self Timer
    • Brightness
    • White Balance
    • Shutter sound
    • Color Effects
    • Fun Frame
Resolution
  1. Select Resolution then press OK.
  2. Ensure the desired option is selected then press OK to choose SET.
    • 1600x1200
    • 1280x960
    • 640x480
    • 320x240
    • Picture ID
Self Timer
  1. Select Self Timer then press OK.
    • Off
    • 3 seconds
    • 5 seconds
    • 10 seconds
Brightness
  1. Select Brightness then press OK.
  2. Ensure the desired setting is selected then press OK to choose SET.
    • -2 (Dark)
    • -1
    • 0 (Normal)
    • 1
    • 2 (Bright)
White Balance
  1. Select White Balance then press OK.
    • Auto
    • Sunny
    • Cloudy
    • Tungsten
    • Fluorescent
    • Darkness
Shutter Sound
  1. Select Shutter Sound then press OK.
    • Shutter
    • Silent
    • Quack
    • Boing
Color Effects
  1. Select Color Effects then press OK.
    • Normal
    • Antique
    • Black & White
    • Negative
Fun Frame
  1. Select Fun Frame then press OK.
  2. Ensure the desired frame is selected then press OK.
How to adjust the camera settings on Samsung Renown admin_mvu Samsung Renown 0 11-22-2008 01:56 PM
How to adjust the camera settings on Samsung Sway admin_mvu Samsung Sway 0 11-16-2008 08:06 PM
How to adjust the camera settings on Motorola Rapture VU30 admin_mvu Motorola Rapture VU30 0 11-01-2008 11:39 PM
How to adjust backlight settings on Motorola Q9m admin_mvu Motorola Q9m 0 05-23-2008 05:14 PM
How to adjust the camera on Samsung Glyde admin_mvu Samsung Glyde 0 05-23-2008 04:39 PM
