Motorola V750 Discuss Motorola V750 Here.
Old 09-29-2008, 06:44 PM   #1 (permalink)
gabbypig is on a distinguished road
Default How do I disable the V-Cast soft key?
I do not subscribe to the service and seem to hit the v-cast soft key 50% of the time. This gives me the v-cast screen when I open the phone. Very annoying.
Thanks,
Gabbypig
gabbypig is offline   Reply With Quote
Old 09-29-2008, 08:33 PM   #2 (permalink)
I don't think there is a way to disable this on any phones. It's something Verizon "mandated" to all the phone manufacturers to put it in, regardless of whether you subscribe to VCast or not.
Old 12-01-2008, 11:23 PM   #3 (permalink)
dgV750 is on a distinguished road
You can lock the buttons which will disable the soft key from launching VCAST. Opening the flip on the phone will unlock it.
Holding the phone with the flip closed, looking at the front of the phone:
1. Locate the upper button of the combined dual button
above the VCAST button on the left side of the phone.
2. Locate the lower button of the combined dual button
on the right side of the phone.
3. Depress simultaneously the upper button on the left and
the lower button on the right for about 3 seconds.
The external display should indicate that the keypad is locked thus disabling the red VCAST button.
dgV750
dgV750 is offline   Reply With Quote
Old 03-05-2009, 09:28 AM   #4 (permalink)
azuser is on a distinguished road
Default Perhaps there's a way to mechanically disable the button?
I came across this post hoping someone had found a way to disable VCAST on this phone.
Unfortunately, the button protrudes from the phone, and disabling the buttons each time I close the phone is just as much a nuisance.
Has anyone gone into the phone and disabled the red VCAST button mechanically?
azuser is offline   Reply With Quote
Old 03-05-2009, 06:23 PM   #5 (permalink)
You can follow this thread for a seem edit to disable the red PTT button on the V750.
HowardForums: Your Mobile Phone Community & Resource - v750 confirmed hacks
Old 03-12-2009, 09:19 PM   #6 (permalink)
Default Thanks for the link!
I used to touch inside the phones, but that was more than a year ago. My software is likely out of date, and I'm not sure I really want to take that task on again.
Using V CAST Music Phone FAQ admin_mvu VCAST 2 11-07-2009 04:40 PM
V CAST Music FAQ admin_mvu VCAST 0 01-02-2008 10:12 PM
Verizon Wireless Rolls Out New V CAST Today Programming buzzdar VCAST 0 12-03-2007 09:49 AM
Verizon Wireless Premieres 'V CAST Performances' With Over 50 Live Concerts admin_mvu Verizon Wireless News & Announcements 0 07-10-2006 10:31 AM
