Motorola W755 Discuss Motorola W755 Here
Old 06-23-2008, 07:40 AM   #1 (permalink)
DC_Mike is on a distinguished road
Default W755 questions
Am thinking of getting the W755, will check it out at the store today.
A few questions that maybe someone can answer:
Does the phone's exterior display have the ability to be customized? I hate the swirly background that it appears to have and I'm assuming I can get rid of it if I want?
Also, is it possible to get rid of the nasty Verizon logo on the front panel? It looks awful, really kills the look of the phone.
DC_Mike is offline   Reply With Quote
Old 06-23-2008, 08:22 AM   #2 (permalink)
You can customize the wallpaper of the front LCD, the same way you do the internal LCD, on mostly dual LCD clamshell phones. (I have VX8600 and I can do that)
If you are talking about Verizon logo that's part of the phone, that'll be difficult. It's painted on the phone cover itself and most likely won't come off easy without damaging the exterior of the phone.
Old 06-23-2008, 06:34 PM   #3 (permalink)
Yeah, that's the logo I was thinking of. I figured it owould be impossible to remove. Such a bummer.
In terms of the front LCD, yeah, that's what I'm thinking. I'm wondering if you can do things like make the clock bigger, so that instead of small text saying "Verizon Wireless" and the digital clock, it can just read the clock or clock plus date or something.
Old 06-23-2008, 06:49 PM   #4 (permalink)
That all depends on what kind of theme V755 comes loaded with. Go try it at the store before you buy it.
Decision questions ilikeverizon12 Samsung Sway 5 11-30-2008 11:31 AM
putting custom ringtone w755 Rockin'Robin Motorola W755 0 11-16-2008 09:02 AM
How to disable EVDO on w755 DeathGrind Motorola W755 1 07-27-2008 03:03 PM
Motorola W755 admin_mvu Motorola W755 3 05-23-2008 09:54 AM
Motorola W755 Pre Release admin_mvu Motorola W755 2 03-02-2008 10:00 AM
