06-17-2008, 02:56 PM
How to enable / disable auto save messaging on Nokia 6205
Enabling / disabling the Auto Save messaging feature - Nokia 6205
- Select Auto Save Sent then press OK.
- Select the desired setting then press OK. On Auto Save is enabled. Off Auto Save is disabled. Prompt The handset will ask to save each time a message is sent.
