Go Back   My Verizon Users > Complaints Department > Official Verizon Rant Thread
Official Verizon Rant Thread If you have complaints about Verizon Wireless products, services, or anything else, post here.
Old 09-03-2007, 12:13 PM   #1 (permalink)
LG_Bruce is on a distinguished road
Default Family Plan Calls Don't Go Through
Ever since my girlfriend and I started the family plan using our LG VX8300 phones we have had difficulty calling each other.
Calling or receiving calls from any other phones seems to be as normal as any cell phone service. The same can't be said when we call each other. We have about a 50% chance of connecting the other phone.
What usually happens is, the caller hears the phone ring until the end of the 5+ rings then the call goes to voice mail. The phone being called will sometimes signal a new message almost immediately but sometimes it can take an entire day to finally get delivered.
We have taken our phones into the store where we got them. The technicians have performed all the tests they can think of but the problem persists.
If you've experienced the same problem and have found a solution please post it. Any help would be much appreciated.
LG_Bruce is offline   Reply With Quote
Old 09-03-2007, 01:54 PM   #2 (permalink)
Wow. I've never heard anything like that before.
Have you tried changing to a different phone?
Old 09-03-2007, 04:11 PM   #3 (permalink)
On one occasion a store technician said one of us could change out a phone to see if that would make a difference. Not knowing what the problem is or which phone might be the problem one, we decided to try some tinkering on each phone to see if that would make a difference.
Well, the tinkering hasn't made a difference and we haven't been back to the store again. It's difficult to say if one phone is at fault or not because each one passes all the "usual" tests.
I was hoping that someone else might have experienced something like this and that's why I posted my rant.
Thanks for your reply!
Old 09-05-2007, 07:02 AM   #4 (permalink)
Walkie Talkie User
buzzdar's Avatar
buzzdar will become famous soon enough
If you have two phones that CAN NOT call each other most of the time that is NOT a phone problem that is for sure a NETWORK problem. I would be calling tech support right away.
[URL="http://mywirelessusers.com"]MyWirelessUsers.com[/URL] to sign up for verizon wireless Great Deals.
buzzdar is offline   Reply With Quote
Old 09-05-2007, 01:52 PM   #5 (permalink)
Telephone User
JAnthon88 is on a distinguished road
I would have to agree. From a phone standpoint, all phone numbers should work just as well as the others.
Try pressing *228 send. When you hear the prompt, press ONE to reprogram your phone. Do this with each of them. That's the only solution I can think of...
JAnthon88 is offline   Reply With Quote
Old 09-07-2007, 11:01 PM   #6 (permalink)
Like others have said, I feel the problem is likely with the network and not the phones. We have done all the things suggested plus the technicians at the store have tinkered with both phones.
The problem of calls not going through is so random that it makes troubleshooting nearly impossible.
Verizon Calling Plan Update - 4/18/08 admin_mvu Calling and Data Plans 1 05-08-2008 10:08 AM
Upgrading to Family Plan, specifics on phones glenn Ask the Tech? 1 04-01-2008 11:32 AM
Family plan only gives you one new phone every 2 years admin_mvu Official Verizon Rant Thread 20 07-28-2007 07:52 AM
Is Family Plan a good idea? admin_mvu Calling and Data Plans 0 01-16-2007 08:33 AM
Verizon Wireless pitches plan to build public-safety network using 700 MHz band admin_mvu Verizon Wireless News & Announcements 0 09-06-2006 01:34 PM
